TwinTurbo.NET: Nissan 300ZX forum - Safety boost in a NA ???? bad knock sensor
Subject Safety boost in a NA ???? bad knock sensor
Posted by dreamchild128 on April 25, 2008 at 2:21 PM
  This message has been viewed 234 times.
Message I been searching for this answer and can find it. I have 1990 300zx na automatic. I am having some problems with her. First at start up it turn over but barely stays on. It idles up and down until the engine warms up then it's fine no idle problems what so ever. What could that be?. Also It is hesitating from the start until it picks up in rpm's then it's fine. It only hesitates when I move from a stop. I ran an ecu test and it cam back code 34 which is the knock sensor. I cleaned everything I was suppose to clean. I brought a new sensor but noticed the wire is a little exposed, could the knock sensor/ exposed wire be causing the hesitation. I've been reading and all I here is safety boost (isn't that only in TT models)but nothing about the NA. Please help, I notice the
